My 1990 Mercruiser 5.7 hydrolocked after being used this summer for 10-15 hours. There was about 2 quarts of water in the pan and when I pulled the spark plugs, water ran out of the rear two cylinders on the starboard side. I pulled a compression check and found low compression on these two cylinders. Removed the head, did a visual check, no obvious cracks, replaced the head gasket and did a new compression check. Compression was back up to specs. Ran the engine for 10 minutes, pan again had bulk water, about a quart, and there was again water in the rear two starboard cylinders. I visually inspected the exhaust manifold, no obvious signs of cracks, no water tracks in the soot. I also ran water through it with no signs of leakage. My question is where to go from here? Is the block toast? The engine has good compression and runs well, but water is getting in, large amounts in a short time.
The engine is 7 years old, a Jasper long block rebuild, and is raw water cooled, with about 250 hours on it. The exhaust manifolds (GLM) have one season on them.
I'm thinking probable freeze damage, though why did it take so long to show up? The engine has a Marine Science Technology Guardian flush system that I have used for years to winterized the motor by flushing antifreeze through the engine.
Are there any tests that can be performed to determine where the water is getting in?
