I have 2 1975 Merc 850's, one is generally for parts. I wanted to swap lower units because the vent screw was not removeable on the active 850. I pulled both lower units and discovered that the active Merc had a pre-load pin on the top of the drive shaft and the other lower unit did not. Are these inter-changeable?
Secondly, as I attempted my reinstall I can get the lower unit to snug up within a 1/2" to 3/4" with no problems. It makes a contact noise at this point. It will snug up if I tighten the nuts (little force needed/stubby wrenches). Still, just wanted to check if this sounds normal?
Any pointers?
Any pointers?
