Re: Dead cylinder: spark,compression;reed ok: NO GAS
Sorry all, I just got back from a week camping on a lake. Thanks for the good replies!!
Yes it's a lightwin, 3 hp, serial # 3012-25817. my mistake, just saw other posts of fleetwins and got mixed up. I think it's 1951, my dad said that, but I'm not positive. I know there's a way to tell with the serial number somehow.
Certainly the carburetor feeds both and is working.
Your explanation of the spark makes sense to me. I'll test for a 1/4" gap spark, which like I said, I didn't do before. I never knew that the spark could be supressed under pressure, as implied in the post by tx1961whaler, (thanks!!!). Switching coils is a good idea albeit a bit time consuming. However, it's definitely a good troubleshooting thought.
Do I need to purchase a spark tester or is there some other way to do it? 1/4" bent out spark plug?
Compression meaures good in both cylinders, so I don't think it's a trashed cylinder.
Sounds like you don't think I'd see gas on the plugs if there was no ignition. I thought the gas would be sucked in from the piston moving, but perhaps it needs ignition to generate enough vacuum. This makes sense the more I think about it. Yes?
thanks again, good thoughts all around!
yours
Adam
