'73 Mercruiser. It never ends. First time on lake this summer the boat overheated, somewhat extreme. Had the impeller replaced. Next time in lake, gimbal bearing rumbles, had that replaced. Put boat back in last week, had fuel problems, or so it seemed. She'd cut out when at full throttle sporadically (would run at slow speeds) and temp slightly above center line. Tonight she wouldn't start, dribbled gas into carb and got it going. Took it out, everything seemed fine but the temp gauge was showing she was running hot, not in red but close. Turned her off to let her cool. Start her up, run her hard and see that helped the temp but not much, had to shut her down again. Next, she didn't start, I had to be towed in but during the attempts to restart I noticed that she was spewing gas into the lake, it seemed to be coming out of the gimbal/transom ring.
WTF is wrong now!!!???
