Re: Help please
50:1 is the correct mixture for that engine. Before you go for a cruise in it, run it in a barrel and make sure it's pumping plenty of water and the cylinder heads are staying cool. If you can't hold your finger on the heads for 3 seconds, it's getting hot and needs a new water pump impeller at the very least. You should also check the lower unit oil for water and a change of the lower unit oil is the bare minimum before going for a stroll in it. Now that you've got it running, you can do the decarb. which is sometimes helpful in freeing stuck piston rings which may cause low compression or worse. New fuel lines and a new water pump impeller are always wise, too.
Good luck with it,
JBJ
