ebry710
Ensign
- Jan 29, 2008
- 981
I have a BW Outrage with a 1989 Johnson 120 attached. I added a water oil separator before the pump bulb. I am having trouble priming it.
It dawn on me that my fuel system design might not be correct. I have
1) a check valve nipple at the tank
2) 3/8" hose
3) oil water seperator
4) 3/8" hose
5) Pump Bulb
6) 3/8" hose
7) VRO fitting
8) 3/8" hose
9) glass inline filter (to see fuel)
10) 3/8" hose
11) VRO Pump
All 3/8" hoses are connect with ss hose clamps and total system length 6'.
When I took the two filters off the system, changed out check valve to hollow nipple and shorten system to 4', it worked fine.
2) 3/8" hose
4) 3/8" hose
5) Pump Bulb
6) 3/8" hose
7) VRO fitting
8) 3/8" hose
10) 3/8" hose
11) VRO Pump
