rosscopeeko
- Jul 24, 2006
- 57
Hi guys, i need a little help from some experienced boaters. I'm going to buy a wide 12ft boat for fishing and burning around the lakes and occasional river. I currently have a 14ft harbercraft that has a 59" beam and is a little unstable. I run a 15hp yamaha 2 stroke motor. I was looking at the princecraft ungava 12ft which has a 60" beam, and also the smokercraft alaskan 12 which has a 63" beam. I'll include a couple of links at the bottom of this post for both boats. The smokercraft is wider and is quite short and stocky. Will this thing plane ok with my motor? The princecraft has a pointy nose and has the gunnal seats (side) which i like. Do you think it will go through the water better? I'm looking for a well built, stable boat, that will handle the 15 and scoot on the water when need be. I'm in Canada so my opotions to other boats found south are somewhat limited, but if you can offer a good suggestion on another boat, fire away. The smokercraft is $800 or so cheaper, is wider, has thicker aluminum, but my only concern is that it won't scoot through the water. Can you guys offer some insight?
http://www.princecraft.com/Content/en-US/produit/431/Ungava.aspx
http://www.smokercraft.com/showroom/ShowModel.aspx?ModelID=745&SeriesID=16
