took my boat out today started fine, ran fine did not run it full throtle at all just half to 3/4 throtle. shot the motor off to try some fishing with no luck on that spot try to start and had trouble starting it. finally got it started then at this the motor started spaterring like one plug is not firing or something try to give it more gas just spaterd more i was able to nurse back to the dock on about 1/4 throtle. trailered the boat a quick run to west marine for some new plugs. gap and replace plugs (champion) put boat back in the water started fine so went back out same problem spaters. did i say that right?
from both times that i have taken and replace the plug, plug on cylinder 1 has white foamy substance on it. the other plugs are fine.
