Needing Help on a cooling problem on my 1993 OMC Cobra 4.3 as it is over heating problem only! at idle up to 2500 rpm, when the muffs are on at home there is no problem. It has a new impellor KIT; I have checked all hoses and pwr. steering heat exchanger no blockage anywhere!! The Y pipe flappers are both working great. Took the boat on the lake, I hooked up a hose to my flush tee inline from leg water pump to thermostat housing, with the hose over the edge of the boat at idle it was spitting sporadic became better at higher rpm but still sporadic,I thought this would be a steady flow of lake water. My t stat works properly I took it out and tested it in the kitchen.any thoughts would be appreciated.
