I have a 87 scarab with a built 350 mag, by built I mean high compression pistons, performance heads (2.02/1.60), RPM intake manifold, 800cfm Holley carb, kodiak exh manifolds and clay smith cam.
I got a good deal on the boat and had it all gone through. New head gaskets because of leak, new lifters and push tubes, had the heads checked and redone.
I had the timing set to 8 degree BTDC and the motor ran great out of the water with muffs. Checked compression and have 170-190psi cylinder pressure.
I put the boat in the water and it won't run over 1700 RPM? Acceleration is smooth up to that point but won't go any further?
1700 Rpm comes at quarter throttle and I can continue to give it more gas but it won't increase RPMs.
Boat also had a full tune up with new cap, rotor, wires, plugs, and ignition sensor inside the cap.
Any suggestion would be appreciated!!
