Basszilla4
- Jun 5, 2008
- 44
I recently installed a set of Faria gauges. Speeometer (0 - 65mph), Tachometer (0 - 8k rpm), and Fuel (E - F). Everything works great except fuel gauge. These all were bought off eBay in a set and were used. Boat never had a fuel gauge so I bought a Moeller 3 wire sending unit and installed into tank. No float arm. At first, couldn't get fuel gauge to work/function. I checked the ohm's from sending wire on sending unit. Seemed to work fine. Don't remember exact readings, but if I unscrewed sending unit and slid up and down in fuel tank, the ohms readings would change.
So, I thought it was a faulty fuel gauge. I sent gauge back to Faria and they sent me a brand new fuel gauge. Still wont work. Boats motor is a 1973 Johnson 65hp. Here is how everything is hooked up:
All three gauges have their 12v lights hooked in a sequence through a fused toggle switch. All work fine.
Tachometers 12v power comes from ignition key purple wire from control box. Ground is off instruments lights ground, and signal wire is from gray wire from inside control box. Tach works great.
Fuel gauge gets 12v from same purple wire as tachometer in control box. Ground from same instruments lights ground. And signal from fuel sending units signal output terminal.
Fuel sending unit has three wires. Red to battery positive post, black to battery negative post, and white to fuel gauges sending terminal. This unit was bought brand new.
Now, I know its not the gauge being brand new from Faria, and sending unit seems to work. My thinking is it could be how I have it wired. The only thing I notice (and happened with old fuel gauge) is with the tachometer. Before fuel gauge was connected, with key off, the tach needle would read slightly below zero. When key was turned on, the tach would zero out. As soon as I connect sending wire to back of fuel gauge, it causes tachometers needle to fall WAY below zero. Almost to the eight. Tachometer will still zero out when key is turned on, turn key off, and tach needle falls like a stone.
Anybody have any ideas? Anything? Please help. ANY information would be GREATLY appreciated.
Thank you.
Sincerely,
Errol (Basszilla4)
Thank you.
Sincerely,
Errol (Basszilla4)
