9.8HP Merc oil change
SBellew
I just got my first boat. Bought it from my uncle and it has a Merc 9.8 on it. Does this take oil or just the oil in the gas mix?
o/b tech
Re: 9.8HP Merc oil change
What you have bought is a two stroke and requires a 50/1 fuel to oil pre-mix in the gas tank for lubrication. Any retailer that sells motor oil will probably sell a TCW-3, 2-stroke oil for the marine environment. Nice looking unit.
Hope the info helps.
SBellew
Great, so the lower part of the motor does not require any oil?
bootle
Yes, the lower unit requires a marine grade gear oil specifically for the lower unit.
CharlieZulu
Unless you know it has been done, I would drain the oil from the lower unit and put new stuff in -- it's easy to do, although it's a bit messy (at least when i do it :redface:). Then you're ready to roll.
SBellew
Sweet, I will look at the motor today while I am checking trailer lights, trolling motor and replacing a couple pieces of wood.
SBellew
I looked at the engine today and could not determine where to change/flush the oil in the lower part. All I saw was a screw labeled 'FLUSH'. My serial is 5638605. From the charts I looked at, the 9.8HP 110 only goes to 520xxxx before jumping up to702xxxx. Could that be the wrong cover? If so, what is my engine? Cannot find the serial anywhere.
emckelvy
The "flush" screw is for flushing water thru the powerhead with the motor not running. Unless used regularly, usually will be stuck and difficult to remove. So don't mess with that one. It's better to flush the entire motor in a barrel anyway.
Your drain and vent plugs for gearcase oil are way down there, on the gearcase itself. In fact, in the 2nd picture you can see the vent screw/plug, just above your hydrofoil unit. The drain is farther down on the rounded part (aka "bullet") of the gearcase.
Here's a recent thread that you could consider "Gearcase 101". It'll run you thru the very basics of doing this simple but Very Important task:
http://forums.iboats.com/showthread.php?t=259698
HTH & enjoy your new rig!...........ed
