shioner2001
- Mar 31, 2008
- 44
So, that title should pretty much sum it up. Any ideas? Kidding of course. Here we go. 87 Four Winns Horizon 170, Merc 165, Alpha One. Just installed a new prop yesterday (21p aluminum) and when I took it out to the lake today and tried to get on the throttle, the engine revved, but there was no drive. At low speeds getting out of the no wake, the boat was fine. It also shifted into reverse just fine. But, like I said, when going from low throttle and slow cruising to a higher throttle or hammer down, it just revs and stops transferring power to the prop.
So, I took it home and this is what info I have for you. When I put it in forward gear, the prop will not spin by hand in the reverse direction, but "clicks" and spins relatively freely in the forward direction. Vice versa when I put it in reverse. It spins relatively freely in reverse with the "clicks", but will not spin at all forward. The clicking sound is coming from the lower unit. The only variable from when it ran great to this situation was the prop change. I've searched around, but didn't see this exact scenario, or at least described such as this. Any thoughts or ideas?
