sprouticus
- May 12, 2005
- 208
hello all.
I have a 1992 90 hp evinrude. It's been a pretty good motor to me. I had an issue with one of the spark plug boots coming off about a month ago.must have gotten the wire snagged on the cowl, and I never even noticed because I was just trolling that trip. next trip out, no power. so i lifted the cowl, fixed the problem, using a little electrical tape for good measure......good to go. yesterday, a month later, I was out tubing with my GF. everything is going fine for about an hour, then we lose power. seems to be familar power to last time, so I check under the cowl for disconnected wire. its still good. we limp back to the marina/parts store and I buy a new boot as they don't have the proper wiring kit in stock. it's not even the right boot, but I figure I can get the day outta it. it works great for about 10 mins, then it's acting like its running off 3 cylinders again. then it got even worse......like it was running off of 2 cylinders. I called it a day.
just came in from outside...........did a compression check. 105, 110, 100, 95. the top 2 cylinders are the 105, 110. I also changed the plugs, and replaced the wire for the one giving me problems.but still with the same boot, as thats all I have for now. can't do a spark test, as i'm all alone right now...gotta buddy coming over soon but we're heading out fishing (with the kicker motor) I did however pull the plug wires off as she was running. no difference on the top 2 cylinders.
can a motor even run on one good firing cylinder???? I think it was when I pulled off one of the bottom wires and noticed a huge difference. did not change like that when I pulled off the top wires.
anyway. is this a coil problem??? or something more serious do you think???
appreciate the help
thanx
dale
appreciate the help
thanx
dale
