60 hp 1967 evinrude. a year agoe pulled motor to replace gearshift bell crank on exhaust housing. put the motor back together, including new water pump, and now have cooling problems. Engine runs hot. Have removed thermostat and engine still runs hot. I am getting water thru exhaust port, with thermostat removed, but I don't believe this proves good flow. any suggestions??????? could i have mounted copper tubes to wrong outlet holes in end cover and would this cause a problem?????any way to check without repulling engine?????
No overheat alarm on this motor, but when I can boil water on the head I shut down assuming its too hot.
