This week I picked up a little Glasstream bass boat with a non-running 85 Force on it. I want to give this motor my best effort before I give up on it. The flywheel turns, but the prop is stuck solid. It won't move whether I put the motor in neutral or in gear. I took the drain screw out to see what the lower unit oil looked like, and uhh... no oil at all. It's been sitting a year, what's the chances the lower unit is seized beyond help? Any tips on what I should try?
Thanks, here's a pic of the motor. It's in great shape, except for the missing skeg. The wiring looks especially good for it's age.
EDIT: Let me add that the prop can easily be removed from the prop shaft, but the prop shaft will not turn. That's a better description.
