Hello everyone,
First i'd like to say that im new to the forums and im happy to be a part of this great community!
I purchased a 1971 2hp Evinrude a couple of days ago from the original owner. The motor is in great shape, has 40-60 hours on it (according to the owner), has no rust.
The previous owner said that it worked perfectly last time he used it 2 years ago.
I replaced the spark plug (champion J6C, cleaned the carb (it was actually pretty clean even before i cleaned it), replaced all the parts in the carb that came with the original carb kit from Evinrude dealer.
I took out the sparkplug and it sparks fine when i pull the cord. The fuel tank and line are perfectly clean. Carb is clean. Compression is 60-65 psi, which is a bit low but it could be because the motor was cold and sitting for 2 years.
I must've pulled the starter cord over 300 times today. It started 4-5 times, and ran for 2-5 seconds before quitting. Most of the times it did start, both mixture adjustment knobs were fully closed. Perhaps it was getting too much fuel, and with the knobs closed it started and ran untill burning up the fuel leftovers?
I think (and hope) that the problem is related to the mixture adjustments. This is my first engine where this is done manually, and i have NO idea where the knobs should be. I tried starting it with knobs in different positions, without much luck.
The engine "feels" as if it has to run at wide open throttle for a few seconds to "break in" after 2 years of sitting. The problem is i cant get it to start and run. Should i try some of that "quick start" fluid to help it start?
What else can i try?
Any advice or help is greatly appreciated!
Best reagrds, Dennis
