jeremy5780
- May 8, 2008
- 147
i just rebuilt a 1998 90 hp cross flow put in the test drum and fired it up. Motor runs good other than it idles high i dont have a tach hooked up so i cant give exact rpms but from experince i can tell it is idling high i tried adjusting all the idle screws ect with no luck i can back the cam and follwer off so they are not touching the throttle valve and all the flaps inside the carbs are fully closed and with nothing touching the throttle valve it still idles high. If i try to puch on the throttle valve to close the carbs it does nothing but if i open them it revs up with no hesitation I have not tried to mess with the timing nor have i taken the carbs apart to check the float. Any ideas?
