Joeman3519
- Jun 18, 2008
- 13
Hello, I'm new to boating and just damaged my prop soo... I have a 1995 Mariah Talari 200, with a Mercruiser 5.7L and an Alpha 1 out drive, currently have a 15.3X19P aluminum 3 blade Solas prop, deep v fiberglass hull. WOT is approx. 4500 rpm. The boat is going to be used as a wakeboard boat and will mostly operate in the 2300-3500 rpm range. I realize that trim tabs or smart tabs will help me plane out faster, but since I am replacing the prop I was wondering if going to 4 blades will make a difference. Also I have the usual questions about props, even after reading the prop tutorial on this site.
I want to get the best gas mileage out of this engine, will a 4 blade help or hinder? Since I won't often be travelling at high miles per hour is it worth it to get a stainless steel prop? If I stay with a 3 blade would anyone suggest a change in diameter or pitch? Thanks in advance for any advice.
Joe.
Joe.
