Hi all, I started this discussion in the general section but I think it should be moved here.
Anyway, we have a 50hp 74 Johnson which I believe has a fuel starvation problem. Initially the motor started and idled and ran at low speed (10mph) very well.
I went ahead and changed the plugs and took it back out. With the new plugs, we were able to reach 25-28 mph gps but only for about 5 minutes. We started to lose rpm's again and went back to about 10mph. After about 10 minutes of putting around, the RPM's came up again for about 5 more minutes. Again, we lost the RPM's and the boat slowed for the rest of the 1 hour trip.
We thought it might be water in the fuel? Fuel Pump? Dirty fuel lines or Carb.
What I don't understand is that at idle, we can use the choke leaver beside the shifter to rev the motor up to high RPM's but when we put it in gear, the RPM's die. The other thing is why did it run well with the new plugs initially? I checked all the hoses for leaks and they all look good.
I have the manual and was going to check the fuel pump but I'm not really keen on turning over the motor with gas flowing out to a container.
The manual also said that if I were to remove the fuel pump and squeeze the bulb that if any fuel is coming out the back vacuum hole, that the pump would need to be replaced. Is the diaphragm the only thing that could be wrong with the pump. Is this a good test? The carbs were rebuilt last year so I don't suspect them but who knows. What about carb cleaner that goes in the gas tank. Does this stuff work?
Would it be ok to run the motor in a 45 gallon drum at high rpm's?
Thanks for your help.
