Re: Spark and gas but wont run, 225HP
First, verify compression and SPARK on ALL cylinders.
Second, grab onto a timing light and verify that the timing is within the prescribed range, i.e., that the flywheel key has not sheared and shifted the timing.
Inspect your spark plugs.
Once you have established adequate compression, spark and timing, only then can you begin to suspect that the fuel system is at fault.
DO NOT ASSUME that anything is right, test and re-test each cylinder, check the battery to ensure adequate cranking speed. Slow cranking will not produce a hot spark and make an engine very hard to start. Check battery cable connections, both ends, both cables.
