Its a OMC 800 stringer outdrive with the hydraulic ram setup. Currently I can hit the button and it will run then stop mid stream, then it won't do anything until I turn the key off and turn back on... It does it while going up & down.. So it is working intermittently then just stops.. I can hear the solenoids clicking while pressing the buttons up and down.. So I'm ruling out the solenoids and thinking its the motor, or brushes in the motor. Does the system have some sort of overheat/thermal protection on it? Anyone else have this problem??? Can I just replace the motor or do I have to replace the entire pump unit?
Thanks
Thanks
