Basszilla4
- Jun 5, 2008
- 44
Hello,
Sorry to pester you all with another newbie question. Just got (new to me) boat legal and on the water for first time. 1984 18ft Grumman aluminum flat bottom with 1973 65hp Johnson 3 cylinder. Runs like brand new. Only problem, was not original motor for boat. There is more power than for the weight of boat. When going to WOT, boat reaches top speed in seconds. Have to back off because it seems to over-rev motor. Looking into buying a higher pitch prop to fix this problem. On there now is a 13 3/4 x 15. Seems to be waisting power.
Doing research, I find the magical rpm's for this motor is between 4500 - 5500 at WOT. So, before I spend big bucks on a prop, would like to get a tachometer. Been told rpm's is how to determine prop selection. Not too high, not too low.
My question is, what is a pole on my motor and how many do I have or need? Or, can a tachometer even be hooked up to this 2 stroke engine? In my research, I found I might have a 12 pole. If so, how many pole tach should I buy and how do you install? I have hooked up tachometers in cars before, but never on a outboard.
Thank you in advance for any info that might help.
Sincerely,
Errol (Basszilla4)
Sincerely,
Errol (Basszilla4)
