I have a 96 5.7 mercrusier with a 2bbl carb. This year after its winter storage the voltage is fluctuating. At idle with nothing else on its fine at around 13.5 volts. I turn on the nav lights and it drops to 12.5, add the blower and radio and its below 12 volts. If I have nothing on but run the engine up to 1500 rpms it again drops to about 12 volts. I've already replace the alternator. I did notice that the wire for the electric choke was not connected to the alternator so I connected it accordingly but that just made things worse. According to the shop manual the choke should have the pur/yel wire and a ground attached. there is no place to attach the ground though. anyone have any ideas? I did all the testing according to the shop manual on the 1st alternator and the voltage regulator should it needed replacing, it was putting out 15.5volts. The new one seems fine though. Is something else fried? Help Help.
