Hi all, Got a 5.0 efi 240 hp driving an alpha one gen II / 1:62-1 in a searay bow rider 200 year 2002. It was a nice boat untill i Let a mate use it and the plonker ended up on the reef James Bond style.
The lower unit is smashed at front (hard to see in pic), bell housing smashed and gimble ring smashed.
In order to fix it 007 has sourced an alpha ??? drive s/no. 0B534839 with on outer transom plate attached. see attached pic
From information i have gained from this very informative site i think this may have been made between 83-90 and will not work on my boat as the inner transom will be different and the gear ratio will be wrong as it was on an old 4 cylinder motor (Decal is missing I will check the letter on the U joint and count the teeth when i next get the chance)
---Anyone know what year this 0B534839 drive is ?
---Is it an alpha or an alpha 1 gen II ?
---What other type of damage should i look for other than the gash in the hull ie engine damage, power steering rack , gimbal bearing damage ?
---Will an old alpha work as good as an aplha one gen II ? (that had been working brilliant) ie shift good and be as reliable and robust. Boat is used for wakeboarding, skiing etc.
Brgds
FLX
Brgds
FLX
