Anyone have any suggestions? Under the steering wheel looks like some type of gfi push button breaker/fuse. Can't figure it out.
Paul
Thanks for the post....actually figured out the problem. Prior owner installed another power lead to the battery. I hoooked it up and it was all set.
Thanks again,
Paul
I hear ya on the gas! Lot of floating I guess! lol
SOOOOOOO another question. Everything in the boat works fine. Next to that additional wire for horn/radio I found another wire attached to a 10 amp fuse which says bildge (looks like it should be hooked up to the pos on the batt). Currently it is not hooked up and the bildge works. Is that power cord for the auto bildge?? I think it is, not so sure. Just thought it was weird everything worked but it was not connected.
Paul
Yes you are absolutely right! The manual bilge works, not the auto/float.
Thanks for the suggestion!
Took her out over the weekend and found that the Speedo was not working. I know the dealer removed the lower unit for maintenance. I talked with them, looks like the forgot to hook up the speed tube that connects to the lower unit. I found the tube, hooked it up, but have not tried it out on the water yet...soon I hope!
Always something first time in the season lol
Paul
Oh and this was on a B3 sterndrive.
