Last week I bought a boat with this motor on. After hitting the water and traveling along @5000rpm for about 10 minutes Engine cut back to 4100ish and wouldnt go any higher. I checked the water seperator and drained anything in it. And away I went. Well today I have the same problem. I was running directly off a freshly filled tote tank, so fuel quality is good. I have replaced all fuel lines too. I was wondering if maybe one of the sensors is playing up? If the engine limiter is resticting the rpm, will it still restrict it under no load? Also I noticed that after stopping there was a little steam coming out the pee hole. Water is flowing thru the pee hole. Would a naffed impellor cause the rev limiter to come on?
Also if someone was able to tell me the correct spark plug type and gap setting please
