Re: Plastic Peddle Boat Repair
http://www.urethanesupply.com/
http://www.westsystem.com/ss/plastic-boat-repair/
http://www.hejet.com/welding_rods.html
I repaired a an ABS Mohawk Intrepid using the West System Method. Worked out great. With the plastic rod welding the heat is critical, to much and the work melts away. I did a field repair on a HDPE Ocean Kayak with some marine epoxy putty from Home Depot. I have yet to need a permanent solution.
Check your local auto body and paint supply for 3M plastic bumper repair
products. GH
products. GH
