Re: Okay more probles...
UPDATE 3
Okay - it's been a few days since I was able to get out and work on the pain in the ***.
Good news, I put a fresh charge on the battery and was able to get the motor to fire up!!!! It ran for about 3 minutes and seemed to idle fine. It finally died out and I wasn't able to get it refired.
Bad news, pulled the plugs and found fresh water in cylinders 6,4,2 left side only. I also checked the dipstick and water wasn't going pass the rings or in the blocks and wasn't mixing in with the oil, it was just at the top of the cylinders which I think is a good thing. So obviously, I beleive I have a leak somewhere in the mainfold riser area on that side. Anyone have any guesses? Where I should check first?
I felt like I might be able to save the motor and I am learning a lot as I go. So thanks for all of your help.
Andrew
