Re: How does your boat track?
yep, thats the trim tab. if yer boat pulls right (starboard), turns easiest that way. ya need to adj. the tab to right to counteract that pull. if it pulls (turns easierst) left(port). adj. the tab left. these tabs are to be adj. for when yer at yer typical load, trim, and speed. all other conditions. the tab will not be adj. properly for, so some pulling one way or the other is expected. unless yer at yer typical load, trim and speed. then it should track straight.
my vhull wanders at low speed. but if ya go far enough, it wanders mostly straight. i track straight at my speed that i usely go, around 2.8K, trim slightly up. all other speeds and loads and trims, i pull alittle one way or the other......
