Now that you have the wiring straight is it turning over fast enough or firing?
You should check your battery, Have it load tested. If the battery is good, you may have a dragging starter.
Also check all battery connections and engine main grounds.
I would be concerned that the speeding up at a regular interval while turning over represents a cylinder with no compression (stuck valve or way bad piston rings or hole in the piston), or there is no spark plug in that one. I'm just sayin'.....
im not a mech....but the above statment has merrit.
as well....i would look at the starter to see if it is getting everything it needs....a bad starter will turn very slo...and draw huge amps.
Your carb may have been flooded some form the previous attempts at starting. Having the throttle open between halfway and WOT while starting probably cleared the flooding and got the air/fuel ratio right and the engine liked it and caught. If an engine is flooded then WOT will clear the flooded condition as it cranks for a bit but as soon as it clears and the engine begins to rev up move the throttle back to 1/3 or less. The backfire probably did no damage to the engine itself but it could have damaged some internal carb parts if it is a Holley, specifically the power valve. If the diaphragm on that got damaged then it will run rich at idle and cruising. The fuel bowl can also drain thru the damaged power valve diaphragm into the manifold while the engine is not running and cause a flooding condition on the next startup.
I'm not in the water just so you know but I always use the fake a lake with the hose turned up as far as it can go. That's why I'm concerned.
I think I understand what you mean on the throttle, please excuse the next few sentences if this is old knowledge to you as I rehash it....The throttle should have two modes. One mode will allow the outdrive to go into gear depending on which way and how far the handle is moved. In that mode the engine can only be started in neutral.
Correct.
The other mode should allow only forward movement and will not allow the outdrive to go into gear and the engine can be started at any throttle setting. It sounds like the second mode on yours is achieved with the "cold start" button pushed in. That is the correct mode to use for initial starting (or anytime you want to throttle the engine safely without fear of going into gear) to pump the carb and set the choke by moving the throttle to WOT then pulling back to idle or just above to start.
Hey Cris,
You mentioned about the elec. choke.
I'll see if I can help some. I've recently brought back to life an '75 motor
Some things I have learned on the carb/choke thing u touched on.
Your choke NEEDS to work properly for her to start/run/warmup.
I have a elec. choke rochester'
I believe it should operate like this:
The choke valve(the large flap) should be all the way closed. when cold.
When she starts to turn over, the valve should open slightly( there is a vacuum pull off for this, small funnel thing w/hose)
As she runs, the elec choke will start to open the valve completely, (this is a function of 12v being applied to the pull-off and has nothing to do w/engine)
If after a while of trying to start, the choke will be open, (because 12V has been on) not good if she hasn't started. You may need to let her sit awhile to close the choke.
Make sure if she doesn't start, u turn your key OFF
You can check the choke operation just by keeping the ign. on and watching the valve. it should open slowly as the power stays on.
If she is open as you try to start cold, it will be way too lean and she wont start.
If the valve is closed and she is warm it will be way too rich.
On the throttle u should ......when cold
"floor" the throttle two or three times to Prime the manifold.
leave the throttle about halfway open and try to start.
if she starts, try to make sure she doesn't rev over 2000 rpm untill warm
Not a MECHanic, I just learned these things the hard way,
and by reading I-Boats.
Hope this helps
WK
Or a bad battery, connections or starter.
