I purchased a used boat last fall (1993 50 Hsp Evinrude). The motor had a blown engine and was repaired by Cabelas in 2006. (new pistons/rings - 1 cyl was bored out to .030 over. Also the VRO pump was replaced and was the apparent cause of the motor problem or at least it got the blame. A new water pump was put in but the carbs were not rebuilt going by what the work order said. The owners said they hadn't used it since. (They spent 1,500.00 on the repair and didn't use it? yea right! I bought it cheap enough that if the engine didn't hold, I could still get my money out of the boat/trailer without a loss which is why I took a risk on this motor.)
I took it out for the first time today. Engine starts and idles fine. When I hit the throttle to get on plane, it looses power and the engine surges. Here are some notes I took.
* Compression was checked last fall by a mechanic and in my driveway by me. One set of gauges read 148/150 and the other 128/130.
* Cabelas work order indicated to use double oil for 1st 3 tanks. (18 gallons)
* Using fresh gas mixed 50:1 with Sea Foam (1/3 of bottle to 6 gallons)
* In neutral - 1,200 RPM.
* In gear at first notch, 900 RPM
* Gradual throttle increase - When it hits 3,000-3,500 RPM, it starts to surge from 2700-3500 RPM with no change in throttle setting. This is the point where it feels like the boat is just starting to breakover on plane.
* When I hit throttle down full, it bogs down at 3,000 RPM and has no power.
* Primer bulb is soft and pliable but does not stay 100% firm. (seems about 1/2 - 2/3 as firm as it should) Pumping bulb while driving seemed to help only a minimal amount. RPMs got a slight bit higher before surging began but it was minimal enough that it could have just been my imagination wanting the primer bulb to be the only problem.
I was planning to run the double oil through the break-in period and then have the carb rebuilt. I'm now wondering if I should go ahead and do it now. Could just a primer bulb cause this? It really doesn't seem like this bulb is all that bad to me.
Any help would be appreciated. Thanks
