Frank Acampora
- Jan 19, 2007
- 12,004
Re: Splashwell Problem, Need Solution
You didn't mention boat size and engine size, but if the engine is any decent sized horspower, forget the ohmmeter and get a tachometer. To me, a nice package is: Speedo, tach, volt, fuel, and temp. But, of course, everyone has a different opinion as to what is necessary. I think you will find though that everyone agrees that a tach is essential.
Although pitot tube speedos are inaccurate, they do look nice and do give a rough idea, in combination with the tach, of how well the engine is performing.
Oops--you did say it was a 90 hp but you also said it was manual tilt while in the photo, both the tilt and trim cylinders, and the pump are visible. Is it broken?
That boat should have a 20 inch transom AND both my Glastrons (15 and 16) like the engine mounted with the cav plate about an inch above the bottom of the v--so run it before you change the height setting.
Now, I'm going to make a guess here--if 90 is the max hp on the capacity plate, and looking at the contour of the transom, is your boat a 15 foot aqualift II bowrider? If so, you will have fun with it but she is going to give you a rough ride at speed going over wakes.
