Re: What is better, Seal the Deck or Not?
Kskomro,
we need to be sure we are all talking about the same thing. The Deck is the layer of wood (usually plywood) that fits above the stringers on an aluminum boat. The wood itself is usually sealed with resin and fiberglass mat, or resin alone. You must seal the wood on the top, the bottom, and all the sides. The sides are particularly hard to seal, and very important.
You do not, however, typically create a seal between the wood and the inside side of the aluminum boat. This is done on a fiberglass boat, but not typically done on an aluminum boat. You need to make sure that any water brought on board (rain, wet swimmers, etc) has a relatively unobstructed way to get to the bilge pump where it can be pumped out, and that may be above or below the deck. Some quick rules:
1. store the boat, if on a trailer, bow up where the water can drain to the back of the boat to the drain plug, where it will be drained or pumped out.
2. allow any water collected to drain to the back. This means you need to pay attention to areas that might collect water,
3. if you currently have the deck off, there should be a way for all water to flow under the aluminum stringers, usually at the very bottom of the boat. If you are repacking the foam, keep water movement in mind, as water will likely gather to the bottom of the boat. Give it a place to go, and then out of the boat. You'll have a drier boat, and one in which the deck will last longer.
