Help Guys
I have a 70 hp johnson sat up two years, I have replaced power pack because It was only firing on 2 cyl's. Fixed that took it for a spin idled rough and no acceleration. I had to play with the choke to get to wot. I figured carbs, so I rebuilt them jets and bowls very clean soaked them anyhow. Floats out of adjustment, installed kits. Performed link and sync. Timing off just a little took it to the lake ran beatifully except for acceleration, still bogging but not nearly as bad just had to push choke once. So I repleced fuel tank, all fuel lines form tank to carbs. installed fuel filter & set of coils. Can anyone help me I am scratching my head. Yes the bulb stays hard during acceleration the compression 155 to 118 lbs. Thanks Tim
