Hi all,
I am new to this forum and am trying to get some advice on getting an old 1963 75 hp evinrude outboard up and running for this summer. My grandmother said I could have her old boat if I could get it running. Problem is it has sat since 1997 (at which time it was running fine). Now, it is very difficult to manually crank the engine and the starter can only barely crank it (with a fully charged battery and good connection). I pulled out the plugs and sprayed in some penetrating oil over the past few days with only a slight improvement. It seems pretty seized up. A few questions:
1) Do you think it is worth fixing this motor?
2) What could I do to loosen things up and allow the motor to crank easier?
3) Any other suggestions on parts that should be inspected, cleaned, or replaced?
I don't have much time or $$$ to put into this project, but it would be fun to get it running!
Thanks!
Thanks!
