There are more things than a prop that will cause the rpms to be 1000 low, and I seriously doubt it would be the prop since 1" of pitch only changes the rpm by 100 to 150 rpm. That would requires a lot of change. 7 to 10 of pitch change.
Yes, it worked, you can now click on the pictures and they get bigger.
While the drive looks like a 270, it could also be a 250. They look the same, but the 250 had staight gears, not helical.
There should be a tag on the upper gear box of the drive. What is the first few numbers after the PZ?
well i finally picked her up and here are the details
engine number/b204989
leg number/2784 123c
does this help
also the brand new spark plugs are very sooty(dry sooty) indicating a rich fuel mixture how do i un-richen it ?????
