Thanks for the heads up.
I want to make sure I understand. There are three threaded holes close to the center of the flywheel that are 5/16-28. Can the motor be lifted by an adaptor that will bolt into the the 5/16" holes?
In other words, I will machine a disk and match the bolt pattern of the 5/16" holes. In the center of the disk, I will thread a 1/2" hole to attach a threaded loop. I will lift the motor by attaching a chain to the loop. Is that how the motor should be lifted?
Thanks,
Grits
