Evinrude Boater
- Jul 6, 2004
- 1,143
I have the gear case disassembled and I noticed the cap can be installed 180 degrees but there's an oil hole (opposite the part number) that connects with the prop shaft. Should the oil hole be up or down, or does it matter since the gear case will be full of oil. Incidentally, the oil hole was on the bottom when I opened it but I know it's been off before.
