Re: Motor stopped, now wont crank
You might consider finding a new mechanic, if this is the same one that gave it a good bill of health. It is a basic thing to check drive oil for metalic shavings and then refill. For him to tell you the prior owner was at fault because it was low on oil, is a cop out. He should have checked, thats part of the eval you were paying for.
If the drive is stuck on, corrosion on input shaft, etc, there could be other problems. Bellows leaking, u-joint/shift rusting, bad seals and bearings. If he is not experienced in Merc i/o drives, take it to someone that is.
