Haut Medoc
- Jun 29, 2004
- 10,645
Re: results of compression test GM305 1978(not running WOT)
Did you try running an external tank with fresh fuel?....
I would.....
This is a fuel issue....Hi all
Well, today i went for a run to check some more things.I warmed up the engine
and i caught 3000RPM.I was traveling for two minutes until the engine started loosing power and then died.Now i thought is a good moment to see the results of a warm compression test.And to my surprise the starboard side head that counted 145-140
-133-127 with the engine cold, now counted perfect(all of them 150-155).What kind of SURPRISE is this????
How do you explain that?All the valves of that side had problem and now dissapeard? It doesn?t sound logical.(The port side when the engine was cold had the three cylinders 150-155 and the last aft 145 and with the warm test they remained the same).Do these numbers may be affected by a leak to the intake manifold which is the most possible reason for my troubles?I think now i have to take out that weer square bolt of the intake manifold and connect the vacuum gauge somethin that i should have done many months ago.(Why there is never enough time the first time.........Don S says!!!!)
Anyway i need your opinions
(Carb, fuel pump,distibutor exept rotor ,gas tank, filters,coil checked or replaced.Ater dying the engine starts up again if you wait for a while and then the next dying will come sooner.)
I would.....
