Here is what I have done/know:
-fuel is good, new gas lines, tank is clean, primerbulb retains pressure, relief valve is open
-new impeller
-carb kit installed, new needle valve that is turned 1 and 1/2 turns out
-all new wiring from key switch to battery and solenoids.
-spark was good last summer when I checked it last
-I acquired this motor last summer and have not got it to run right yet, but I am determined. Usually it will start and run anywhere from 3-20 seconds before dying. I think the only thing I have not done is to take off the flywheel and take a look at the points and I have not replaced the fuel pump. The previous owner said the reason he quit using it was because the lower unit was bad, but I think he is wrong because I realized that the shear pin was broke, so I replaced it and I think that was his problem. He never said anything about it not running well, so I am trying to figure out what could have went wrong in about 2 years of sitting. Please don't recommend cleaning the carbs, because beleive me I have put a kit in and it is as clean as a new one. My question is: Do you think it could be the points or possibly the fuel pump? Thanks for the help, hopefully together we are closer to having another outboard motor running like it should.
-new impeller
