Re: Johnson 30 HP, Starting-up
Appreciate all the advise, thanks guys. I'll change the gearcase oil. The impeller's seems to be in good condition, ('tho, I'm not sure what a worn one looks like. i'll have to change the gasket when I put the gearcas back). I've got no idea what condition the carbs are in, but going by the general condition of everything else i'm inclined to think it wont be a problem. I don't have the kit to do a proper compression test, turning by hand all seems as it should -i'll check again when i've put the lower unit back. So, double checking... I'll turn the key, see if it starts, if it does - i'll check there's water coming out. If all's good then i'll let it idle for a while. If the carbs need attention, it'll stall or I'll know, and be able to shut it down quick. ?
Sorry, should have added it'll be running on a pre-mix 50:1, so if it runs the mix'll be good!?
