my motor mounts aren't so straight forward...for a 454 which causes the mounts to be a little wider and more substantial than similar models with 351's that i've seen.
the old wood was so mushy i couldn't tell what was going on...it had already went, haha. the old inner stringers seemed to have the motor mounts notched into them. the old motor mounts were something like 5" wide and 5" tall and sat on the outside of the stringer.
should those stringers run continuous (3/4" x 2 for the inner stringers) with the motor mount area's added to them or should i somehow tab the stringers and mounts together?...make sense?...pic...this overhead gives a good view. maybe 1 1/2 of ply plus some 4" PT lumber to build it up?
overhead
this is closer, you can see how the exhaust pipes poke out from under the deck
overhead
