I have the original gas tank that came with this boat(plastic). The cap does not look like it is vented(it has a hole underneath but it does not come out the top nor does it have a screw). Could this cause a problem or does it need to be vented?
Built in tank? If so, it should have a vent hose and a fuel hose. Some fixtures accomodate both hoses, some boats have two separate fixtures.
More here: http://www.iboats.com/basics/fuel_system_tips.html
1996 Johnson 35hp. 3 cyl.--have not done any main.---got new plugs to put in today---started doing this last year---have owned the boat/motor since last spring---before then it sat up for appr. 2 yrs.---this boat/motor was repoad. and we got a really,really,REALLY good deal on it---16ft. Grumman boat---seems to run pretty good top end just hard to start most of the time.what motor? hp,year? what maintanance has been done, how long ago? last time carbs were cleaned, and rebuilt with a kit? last time you checked compression and spark? di it just start doing this? how long have you owned the motor?
