j442w30
- Jan 9, 2007
- 264
Hi everyone,
I've got a 98' Chevy Cavalier and it pulls slightly to the left, the tire pressure checked out so I took it in for an alignment and they called back and said my front control arms need to be replaced because the bushings are bad. I asked them if they could just replace the bushings but they said that by the time they get them pressed out you're just better off getting brand new control arms. To replace the control arms and do the alignment they said would be around $500 (they said the control arms cost $150 apiece plus $50 to install them).
The car has 115,000 miles on it so I can understand the bushings might be worn out but I checked at my local parts store and they said a control arm with new bushings and ball joint is $100.
Is there any way to check the condition of the bushings right now? The car handles fine and there is no slop in the steering, just that it pulls to the left slightly. Is it hard to replace the control arm? From what I remember when I last had the tires off all it seems you would need to do it unbolt the arm from the body and break the ball joints loose to take it off.
I do all the maintenance I can do myself and I would be willing to attempt this job. Does anybody have any suggestions?
Thanks
Thanks
