Re: Motor only runs whith choke on
Carb rebuild couldn't hurt and is a good idea if the motor is new to you, since you don't know when it was run last. If you rebuild them and you still have the problem, try smearing some grease on the external portion of the throttle butterfly shaft wher it meets the carb housing - there is sometimes wear in this area, which will cause the carb to suck air in. The grease may block that temporarily and aid in troubleshooting, but it isn't a long term fix.
