krisnowicki
- Jul 11, 2007
- 1,172
Well you guys always have the right answers so here we go see if you can help me figure this one out.
I posted a while ago after a repower I had some water in the oil pan and milky oil. I immeditely pulled the plugs and got all the water out of the cylinders and pulled the drain plug from the oil pan and drianed everything out.. Since then I pulled both heads to check the sit.
I found the number 5 had a melted plug due to what i think was a slipping distributor and bad timing. There was rust stains going down the brand new manidolds where the risers meet and so i pulled it apart and with your help Don S I found out i had the wrong gaskets. So.... I replaced both head gaskets cleaned all the water out of the cylinders... there is no rust on the walls. I tourque the heads down according t spec and with the appropriate #'s. I used a 1/2 inch torque wrench. I bolted the manifolds exhaust and intake down using new and correct gaskets. I comp tested cylinders and i am getting 120ish + on all ...
NOW. I have a new coil, plugs(gapped right .060), wires, cap and rotor, on a thrunderbolt igniton system. after spinning the engine with no plugs for oil pressure. I put my finger over #1 when it blew air out I put the plugs and distributor in and point it to 1 and nothing.... I spray starting fluid and nothing.
What am I missing I have fire gas and time but nothing... I also disconnected the shift interupt to eliminate that... any help would be appreciated.
pulled the #1
Also, just to be sure i am at #1 TDC what would the valves be doing on that cylinder at that time ?
this is a 350 vortec with thunderbolt ignition... thanks again
pulled the #1
