erikgreen
- Jan 8, 2007
- 3,105
I've decided to build my own replacement doghouse from scratch. It's for my Sea Ray SRV-210 I/O that I put a chevy 350 in last summer.
I'm posting a progress thread here so you guys can point and laugh... I apologize in advance for the slow connection for the pics.
The basic construction will be 3/8" plywood with epoxy and fiberglass. The glass is going to supply most of the strength. I have a lot of 8 oz. cloth, so I'm planning on about 3 layers plus some tabbing.
Here's some pics from the first day's work.
Here's the old doghouse. It's serviceable, but I want something cleaner looking and a bit bigger. I also want to test these construction techniques, hence this project
Here's the cut out plywood for the new one. To save cutting I'm going with a 24 inch high box, with the front and sides slightly canted in so I can clip some items to them and not have them stick out in the way (swim fins). The 4 inch strip at the back is because the top is about 28 inches deep, too much for my 2 foot handi-panels.
I'm using sections of scrap lumber to screw it together temporarily so I can tab the outside with glass. I cut the edge of the lumber (a 2x10 here) to match as closely as possible to the angle of the side it's screwed to.
Then I screwed the whole thing together, for the most part taking care to keep the screws back from the edges so I can install tabbing strongly enough to remove the scrap lumber pieces and glass the whole thing. Here's the inside view:
And here's the outside view after cleaning it up with a router and pad sander. Note that I rounded the edges some, but there are gaps and places I'm going to smooth out with some filler before I cover it with glass.
Also note that screwing down the center of the top made a slight saddle curve, which I was going to eliminate until I realized it helped drainage and also made a natural seat for someone.
Next step is to fill the edges with putty and coat the whole thing with a layer of epoxy on the outside. Following that I'll be tabbing the outside with glass, then removing the screws and scrap "jig" and putting on a full glass layer for strength before I turn the whole thing over and do the inside the same way.
Then it's one more all-over glass layer and on to sanding and painting...
Erik
Erik
