Re: 17 ft Glastron with a Volvo I/O
I had 2 friends with Glastron/I4 Volvo packages. No offense, but didn't like either. For the name that Glastron carries, that parred with the Volvo engine/outdrive just didn't get it in my book.
In agreement with Frank's comments. My version:
Don't remember if that outdrive had a trim tab or not. I don't recall it having one. If you had one and adjusted it properly, you could better control your steering when trimmed out where you belong. I say "where you belong" because the only time you want your boat plowing (trim sucked in, bow down) is when that is the only way you can get a smooth ride. Because, just as you said, your speed suffers and your fuel gph does too.
The effect of propeller thrust on steering is trim (angle with the water of the prop) sensitive. Most of the time you (I) set the tab for the easiest steering where I do the most running. Some rigs have a broad range of control and others it's pretty narrow. Changing prop pitch can affect it also, with the higher pitches being the hardest to control.
A "no-feedback" steering system by Teleflex-Morse (different than standard systems they produced) would help the wheel to stay put when you are having to wrestle to hold it on course.
My 2c,
Mark
